Discussion topic: WIFI speed
This message was authored by: SF30
WIFI speed
The app is telling me that my wifi should have a download speed of around 900mbps yet I am doing a download currently and have around 230mbps. I have done a hard reset and disconnected other devices and even set the wifi to prioritise the connection with the download and no improvements have been seen.
Re: WIFI speed
@SF30
900Mbps is your line speed to the hub, over WiFi this may drop significantly due to various factors such as your location in relation to the hub, device your using, other devices, interference from neighbours.
If you want to achieve 900mbps you usually need to use ethernet.
I am NOT a Sky Employee
