Discussion topic: No WiFi
Message posted on 11 Jun 2026 04:00 PM
No WiFi
Tv is connected to broadband but not internet router shown no light on internet section and red on voice
Message posted on 11 Jun 2026 04:12 PM
Re: No WiFi
@acko+5764
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
