Discussion topic: WIFI Weak signal
Message posted on 29 May 2026 10:45 AM
WIFI Weak signal
My WIFI is working ok but the signal strength is really poor and impacting my teams calls.
Message posted on 29 May 2026 11:33 AM
Re: WIFI Weak signal
@bengray2000 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
