Discussion topic: WI-FI not working
This message was authored by: Ncopelin72
WI-FI not working
  • It just stopped working. On the box, there is no internet light.
Re: WI-FI not working
@Ncopelin72
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
