Discussion topic: Sky box red light
Message posted on 17 May 2026 04:30 PM
Sky box red light
No sky, just red light
Message posted on 17 May 2026 04:36 PM
Re: Sky box red light
@Jim102_
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
