Discussion topic: WI-FI Optimisation
This message was authored by: CB666
WI-FI Optimisation
Question for Sky people 🙂 Is there a backend option for switching off wifi optimisation on my router - not something accessible via router menu etc?
Re: WI-FI Optimisation
Hi @CB666
What exactly about the WiFi Optimisation are you not wanting to happen? As far as I know Sky hubs just auto channel switch, not a lot else goes on.
I am NOT a Sky Employee
Avatar for CB666
I want the WiFi optimisation disabled.
@CB666 Not anything you can do on a sky supplied Hub!
Avatar for CB666
Yeah wondered if there was a back end option
@CB666 The answer to that would be NO. What is your issue if you have one?
@CB666
Answering with the same statement of 'I want the WiFi optimisation disabled' after being asked for further clarification on what exactly you mean by that or what issue you are specifically having really isnt helpful. If you provide more context the forum might be able to help.
This message was authored by: 2muchTV
@CB666 if you are wanting or needing greater control re your network I think  you will have to purchase your own hub/ router/ mesh.
I suspect most hubs supplied by major ISPs are locked to some degree & level.
I use Asus and they have so many customisable features it can give you a headache 😄
Even in Access Point mode (which disables many features) there are still plenty of features I can adjust.
Former Sky HD+, Q and Stream customer
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £31 pm (till October 2026)
2 x FTTP lines: Digi £15 pm 900/900 & Aquiss £36pm 80/20
Connected in dual WAN to XT9 mesh
65" Samsung S92C OLED TV
6 other streaming TVs
