Discussion topic: WI-FI Dropping In and Out
Message posted on 16 Jun 2026 11:15 AM
Broadband signal very good and for the last 12-18 months everything worked fine, until about a week ago where my wi-fi/internet keeps dropping in and out....about every 5-10 minutes when I am on my apple imac. Checked all signals all still good....turned everything off and on many times but still getting it
Message posted on 16 Jun 2026 01:24 PM
Re: WI-FI Dropping In and Out
@RobbDee wrote:Broadband signal very good and for the last 12-18 months everything worked fine, until about a week ago where my wi-fi/internet keeps dropping in and out....about every 5-10 minutes when I am on my apple imac. Checked all signals all still good....turned everything off and on many times but still getting it
WiFi or the broadband speed to the hub?
Firstly, unplug the hub for 10 minutes and then reboot.
If WiFi then have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
