Discussion topic: WFI issues
Message posted on 22 Oct 2024 08:11 PM
WFI issues
Currently getting 125-150 down the line in to the router.
Sitting in the same room (aprox 4 -6ft) from the router. Getting only 46-60 on speed tests. Is it likely to be the router box? or is there something else it could be?
Thanks for any advice.
paul
Message posted on 29 Oct 2024 10:53 AM
Re: WFI issues
It will depend what device you are using, what WiFi technology it is capable of, if any other devices are connected to your hub at the time etc.
Your line speed is only guaranteed over a cable.
Message posted on 30 Nov 2024 06:40 PM
Re: WFI issues
It's never been moved it's contacted in the hall never been moved can't be it keeps cutting out daily now
