Discussion topic: Very slow WiFi
This message was authored by AB-sky-id This message was authored by: AB-sky-id
Very slow WiFi
My WiFi has become very slow over the last couple of days. Using a laptop and ether etc cable every works ok. I have run the diagnostics in the app and everything is apparently working OK- it's not though!
Re: Very slow WiFi
@AB-sky-id  do you have a black or white router?
AB-sky-id
Re: Very slow WiFi
Black for the main box and then a white as a booster. The WiFi is slow near both of them
Re: Very slow WiFi
@AB-sky-id Could you please post your router stats following the link below.
AB-sky-id
Re: Very slow WiFi
Re: Very slow WiFi
@AB-sky-id  What speed would you normally get when it working well as seeing narly 49 mb/s down / 6.2 mb/s up and can see a few colliosion packets on whatever is connected via LAN  is having a few issues.
AB-sky-id
Re: Very slow WiFi
That's a good question that I don't know the answer too. On my laptop on an ethernet cable everything is working OK it's just the WiFi that is loading  pages much slower than normal. It seems more an issue with the WiFi signal than the Internet line coming in
