Discussion topic: Very low wiFi speeds
Message posted on 09 Nov 2024 11:09 AM
Hi, I have the Sky Full Fibra 500, but one week after installation my speeds in the bedrooms in the first floor are 3.81 Mb/s download and the 7.77 Mb/s upload.
The Sky website internet check says that my WiFi is fine, but the speeds are far too low (and they are not stable neither).
What shoud I do?
Thank you.
Message posted on 09 Nov 2024 12:04 PM
Re: Very low wiFi speeds
@Alessandra5 Do you have broadband boost or broadband Max with your broadband subscription?
Message posted on 09 Nov 2024 01:54 PM
Hi,
I have Sky Max Hub
Message posted on 09 Nov 2024 03:21 PM
@Alessandra5 Do you have the broadband Max subscription that gives you extra control over who can be on the internet and what times it can be switched off. As if you have this then you can get a booster pod sent out at no extra cost to help with the Wi-Fi in the property.
Message posted on 10 Nov 2024 02:42 PM
Hi don't know
Message posted on 10 Nov 2024 03:34 PM
@Alessandra5 If you are not sure if you have the Max subscription then give Sky a call and enquire about getting a Sky booster pod they will be able to tell you if there is going to be a cost attached to this.
