Discussion topic: VPN NOT CONNECTING to WiFi
This message was authored by: Childishgimbino
I work from home and I've got an issue with my WiFi - my work requires an IPv4 physical adapter address
I can't connect to the WiFi without resetting the router and the booster every time and it's increasingly annoying.
How can I get this fixed with sky so I can connect to the WiFi? I've tried with work and they have told me that sky need to fix this issue
Re: VPN NOT CONNECTING to WiFi
@Childishgimbino What sky hub do you have white or black!
Avatar for Childishgimbino
It's black
@Childishgimbino See the link to the hubs below, and if you have the Sky Broadband Hub, operates by standard on iPv4 with iPv6 also included,
