Discussion topic: VPN Connection to workplace
Message posted on 03 Oct 2024 11:50 AM
Hi,
We have started using a new sky Max Hub with the sky glass Tv system. Since switching I cannot connect to My workplace VPN. Does anybody have a robust fix for this? Sky has tried to fix this remotely and failed; There conclusion was its My Laptop…….
FYI……. I Can connect to My workplace via the VPN when I travel and using My neighbours Internet.
Last resort, can anybody recommend a new router that will work with Sky Glass system.
I’m not an IT tech…. So, any help would be appreciated.
Many thanks.
Message posted on 03 Oct 2024 12:28 PM - last edited: 03 Oct 2024 12:29 PM
Re: VPN Connection to workplace
You probably need 1:1 Map-T rather than the 8:1 which is now the default with a circuit supplying broadband to a Max Hub.
Current advice is to use the Hub administration settings in the My Sky app to enable UPnP: that should trigger the Map-T change.
Message posted on 03 Oct 2024 12:38 PM - last edited: 03 Oct 2024 12:38 PM
If you complete this form Sky should be able to help.
