Discussion topic: VPN Cisco AnyConnect Disconnecting
Message posted on 29 Oct 2024 05:01 PM
Hi There,
I am using Cisco AnyConnect for my work VPN. It seems to constantly be disconnecting with my Sky Broadband, this has only started happening since upgrading to Sky Broadband Ultrafast1.
Any suggestings on how to resolve this?
Many thanks
Message posted on 30 Oct 2024 11:51 AM
Re: VPN Cisco AnyConnect Disconnecting
@Somersetlu Did you also have to change router?
Message posted on 30 Oct 2024 12:26 PM
@Highlinder My router was changed to the black sky broadband hub
Message posted on 30 Oct 2024 12:27 PM
@Somersetlu Which one did you have before?
Message posted on 30 Oct 2024 05:52 PM
Message posted on 30 Oct 2024 09:30 PM
@Somersetlu Have you tried to Enable UPnP to see if this helps with the VPN. This can be done loggining into the router. You will need to check the tab that it is on.
Message posted on 31 Oct 2024 11:22 AM
@Highlinder just checked the router settings and UPnP was already enabled
Message posted on 01 Oct 2025 11:42 AM
I'm having the same issue only my router is the old black sky box. My Cisco work VPN keeps dropping in and out of connection. Any suggestiosn on how to fix this as I'm unable to get in contact with sky. There is no number for them and the auto bot is useless. My UPnp is turned on so I don't know what else to try. Thank you
Message posted on 10 Mar 2026 05:32 PM
Message posted on 10 Mar 2026 05:39 PM
@SteveG1969 Then if you cannot contact them have you tested at other sites, VPN software is not a support item.
Message posted on 10 Mar 2026 06:08 PM
@SteveG1969 Sky have told us that the issues with AnyConnect should have been solved. Can you confirm that you have a white Sky hub?
Message posted on 10 Mar 2026 09:27 PM
No, i have a black Sky Hub. - SR203
