This discussion topic has been answered Discussion topic: Using my own Asus router with Full Fibre
Message posted on ‎12 Feb 2025 03:12 PM
Currently with Virgin Media (Modem Only Mode) using an Asus RT-AX82U router.
Moving over to Sky Full Fiber 500 and would like to use my own RT-AX82U router instead of the router supplied by Sky. I believe this is possible - although I understand I will loose the ability to use the Sky telephone service and should I require support from Sky I would need to plug their router back in.
Can you please confirm if it would just be the following two settings that would need making on my Asus router -
WAN Connection type = Automatic IP
Client-identifier (Option 61) = anything@skydsl|anything
Are there any other settings that would need reviewing?
Lastly, can I replace the Sky router with my own on day1 or is there still a training/learning period (such as used to apply to ADSL) meaning that I would need to leave the Sky router in for Xdays before replcaing with my own.
Thanks,
Steve
Message posted on ‎12 Feb 2025 03:17 PM
Nothing else needs to be entered. Plug it in after entering the client id
Message posted on ‎12 Feb 2025 08:43 PM
Re: Using my own Asus router with Full Fibre
Thanks @cookiemonsteruk
Do you know if I can replace the Sky router on day1 or is there a training/learning period (such as used to apply to ADSL) meaning that I would need to leave the Sky router in for Xdays before replacing with my own?
Thanks,
Steve
Message posted on ‎12 Feb 2025 08:45 PM
There is no dlm training for fttp you can plug it in right away
Message posted on ‎12 Feb 2025 08:49 PM
Thank you @cookiemonsteruk
