21 May 2023 12:49 PM
Anyone use a different router? What do you recommend? Thanks
21 May 2023 12:55 PM
Our go to router would be any of the asus rt ax wifi 6 routers . They can both replace the sky hub or act as access points along side the sky hub.
P.s. you should see a huge improvement with you new pci-e card.
21 May 2023 01:20 PM
I notice you have a Series X, i have a Series S. What sort of speed is needed for Cloud Gaming any idea?
I get 50 - 55 mbps. Thanks
21 May 2023 01:29 PM
I am not a big online/cloud gamer see below for an idea of speeds
Cloud Gaming Service | Speed Requirement |
Xbox Cloud Gaming | 10 Mbps1 |
PlayStation Now | 5 Mbps2 |
Vortex | 10 Mbps3 |
Boosteroid | 15 Mbps4 |
Shadow | 15 Mbps5 |
Amazon Luna | 10 Mbps6 |
GeForce NOW | 15 Mbps
21 May 2023 03:39 PM
A wireless standard 802.11ax wireless standard 6 isn't likely to help with playing games on Xbox Series S/X over wireless as they only support the wireless 802.11ac standard 5.
