Discussion topic: Using Sky Booster WiFi using Vodafone router
Message posted on 29 Jun 2025 12:23 PM
Hi I have a Vodafone router and sky q box and a sky mini. I also have 2 sky boosters. The Vodafone router I do not think is strong enough enough and the network is picking up a strong signal (I guess) from the sky boosters. I do not have a password to connect to them. I have tried the Vodafone password and that doesn't work.. any ideas?
Message posted on 29 Jun 2025 01:44 PM - last edited: 29 Jun 2025 02:04 PM
Re: Using Sky Booster WiFi using Vodafone router
@Toad117 It will be highly unlikely that you will get the sky booster's to work without having them connected to a sky-hub, tried it to attach to an EE router, setup fine, but would not pass data.!
The sky Q and the mini should work independant and connect but you may have to set that up as a seperate method, that is in the help and search for connecting Q!
Setting up Sky Q | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 29 Jun 2025 02:00 PM
Sky boosters use the WiFi credentials of the Sky Hub they are designed to work with.
