Discussion topic: Surfrace pro connection to wifi
Message posted on 29 Jun 2025 01:20 PM
New fibre installed on Thursday. All devices apart from surface pro are connecting to WiFi. Each time password entered on surface pro device stays unable to connect
Message posted on 29 Jun 2025 01:55 PM
Re: Surfrace pro connection to wifi
@Kerry167 Sky user before the upgrade! Fibre change and using the same hub as before! has the laptop ever connected!
Message posted on 29 Jun 2025 01:58 PM
Needed to update advanced settings, which had changed to default
Message posted on 29 Jun 2025 02:02 PM
@Kerry167 You may just need to get the MS system to completely forget all the wireless settings!
