Discussion topic: Useless internet connection
Message posted on 16 Aug 2025 10:46 AM
My internet connection drops out every day between 10 and 11 am.
its not working now!
whatever the problem is please fix it as soon as possible, or I will be forced to return the router and get a different provider
Message posted on 16 Aug 2025 10:48 AM
Re: Useless internet connection
@PhilGst
You aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
You perhaps need to investigate what else happens between those hours.
Otherwise, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 16 Aug 2025 10:53 AM
Thanks for the reply.
It's amazing that you can type all that info in 2 mins.
This message was the first thing that popped up when I was trying to find a contact.
Anyway, tried all that just about every time the internet connection crashes.
Message posted on 16 Aug 2025 11:03 AM
@PhilGst If you have tried it all, time to call sky and get them to take a look at what's going on!
Message posted on 16 Aug 2025 11:13 AM
On the chat bot waiting for a response, but at least I have finally found a contact number as well
Message posted on 16 Aug 2025 11:16 AM
@PhilGst You did well, they are trying even harder now to hide it away, chatty seems to be it now true multi tasking at it's best!
