Discussion topic: Upstairs WiFi poor
This message was authored by: Smartv
Message posted on 04 Aug 2026 09:14 PM
Upstairs WiFi poor
Smart TV and Nintendo switch poor WiFi upstairs
Find out more
Message posted on 04 Aug 2026 09:39 PM
Re: Upstairs WiFi poor
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
