12
Discussion topic: Upgrading to ultrafast plus. I’ve had a cable delivered. Should I have a new router too?
This message was authored by DY1 This message was authored by: DY1
I've had an ether net cable delivered but no new router. Is this correct please? Normally with an upgrade there is a new router too.
 Thank you
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: Upgrading to ultrafast plus. I’ve had a cable delivered. Should I have a new router too?
@Highlinder
Yes. I reckon any firmware updates are router side any way so they have to be
@DY1  What did you upgrade from and to? Also which router do you have at this time from the link below.
DY1
Hi,
 thank you for responding.
i currently have super fast and am upgrading to ultrafast plus.
I currently have the sky broadband hub.
DY1
@DY1
The sr203 is suitable for both fttc and fttp . The difference is you use the ethernet to plug into the ont instead of the dsl into your mastersocket
DY1
Thank you for your reply.
that's a lot of acronyms that  I don't understand but I think I read your answer as I have all the equipment I need with the ether cable?
@DY1
With ultrafast you get an fibre optic modem (ont) below
You then attach the ethernet cable you received from the ont port to lan port 4 marked wan.  This setup bypasses the inbuilt dsl modem .  So effectively the hub (modem router) becomes a router only
@cookiemonsterukNot on ultrafast, I take it the firmware is the same on superfast to ultrafast on the Sky broadband hub?
@Highlinder
DY1
Will open reach bring this with them? I don't have the fibre optic modem in your picture
@DY1
Yep.  That will be installed on or before activation day
DY1
That's great.
 Thank you @cookiemonsteruk @Highlinder  for your help
DY1
@cookiemonsterukNice to know that all I would need in my case if I upgrade to ultrafast would the install of an ONT, as the cable pull has already been done up to the edge of my property.
@Highlinder
Good to know. They've done the mdu drop boxes where i iive and granted way leave for digging up the carpark yet no sign of OR yet to drop down from the telegraph poles and duct it in
