Discussion topic: Upgrading to fttp and need to split bands
Message posted on 22 Jul 2025 10:57 PM
Re: Upgrading to fttp and need to split bands
@MrTea1100 Sorry but you raised the question that you wanted the 900Mb/s service, You can get that, Ethernet will get you all the way speed wise IF your PC/Laptops etc can do it, and wireless falls short a little on the SR203 which gives you all the splitting if you need it, Sky Max does not allow splitting in anyway Ethernet is the same as above, wireless will be slightly faster but not by much!
ISP connected is just plug and play, Asus you will have to work at get it all connected and tuned to how you want it all to be!
With either you may come across issue's as going up to wi-fi6 is different to what you have now!
AP's you need to work out what you want and need both connection and type!
