Discussion topic: Upgrading my broadand
This message was authored by: lindz88
Hi
Ive got ultrafast broadband plus at the momnet and looking at upgrading but can anyone tell me which is a better option.
Do i go for the gigafast or the sky wifimax?
Tried to look online to find out which is better but cant seem to find anything on the Sky wifimax.
Re: Upgrading my broadand
@lindz88
Sky max is a hub that can be used on fttc and fttp connections and costs £7.50 pm on an 18 month contract. If is wifi 6 router and should give you better wifi within the house .
Gigafast is on the otherhand a 1Gbps connection to the hub using the sr203 hub
The question is do you need the faster speed or just better wifi
@lindz88
WiFi Max is available as an option on any Sky Broadband speed using FTTC or FTTP.
https://www.skygroup.sky/article/Sky-Broadband-releases-its-most-powerful-WiFi-yet
It's worth considering if you really need the features (particularly Parental Controls) for the additional cost.  The 'better' WiFi may be advantageous for 500Mbs and Gigabit FTTP, but other mesh systems are available.
