Discussion topic: Upgraded to FTTP and now wifi connectivity to xbox one has decreased why would this happen ?
Message posted on 04 Feb 2024 06:02 PM
Moved from Superfast to FttP on Friday and the connection to an Xbox 1 has decreased . Original router kept sky hub is this the issue?
Message posted on 04 Feb 2024 08:44 PM
Re: Upgraded to FTTP and now wifi connectivity to xbox one has decreased why would this happen ?
Did you stay on the same superfast services when changing to fttp or did you downgrade or upgrade the package?
is there much difference in location from the old bt master socket to the new Ont?
Message posted on 05 Feb 2024 05:25 AM
We upgraded package the new box is on an external wall approx 1m from the old Bt box I have purchased a longer connection cable for the hub as the one supplied by sky was far too short so it sits in the same place as previously
Message posted on 05 Feb 2024 07:08 AM
Which standard of Ethernet cable did you buy to connect the hub?
