This discussion topic has been answered Discussion topic: Upgrade to Sky Fibre
Message posted on 31 Dec 2024 11:20 AM
Hi
im due to upgrade to Fibre on 3January, and have received a new router. Can I install before upgrade is complete? Also, if I do, will I still retain my Q services?
mike
Message posted on 31 Dec 2024 11:59 AM
@MikeN1 the hub you received will connect to a Sky FTTC service simply usecthe cable you have for your current hub and connect it to the modem input.if the new hub is black it will connectvto your existing Q bixes just like your current hub.
However if you have the new white Sky hub that can only connect to your main Q box directly. If that applies it may be better to wait until your full fibre connection is installed.
