Discussion topic: Upgrade to GigaFast+ Hub
Message posted on 10 Oct 2025 12:38 PM
I recently moved to Sky broadband with the Full Fibre Gigafast package (900Mbps). This came with the Sky Max Hub and unfortuanetly it only has 3 LAN ports, with the 4th used as the WAN port. My current home network setup is assuming the use of 4 LAN ports and I see that the Gigafast+ Hub has 4. Is there anyway to uppgrade to this hub, without having one of the Gigafast+ broadband packages ?
Message posted on 10 Oct 2025 12:54 PM
Re: Upgrade to GigaFast+ Hub
@gmhaggis No, but you can go buy and add on a Gigabyte unmanaged switch to take care of the number off ports that you require and an additional patch cable if the switch does not come with one!
Message posted on 10 Oct 2025 01:56 PM
That hardware is currently only allocated to Sky Broadband customers who are connected over CityFibre infrastructure.
Message posted on 10 Oct 2025 02:28 PM
@JimM1 wrote:@gmhaggis No, but you can go buy and add on a Gigabyte unmanaged switch to take care of the number off ports that you require and an additional patch cable if the switch does not come with one!
I realise that, but was hoping to be able to avoid another piece of hardware with another power supply. Previously, the 4 hub LAN ports conveniently connected to 4 patch panel ports, activating 4 ethernet ports around my apartment. Even a 2 way splitter/switch would require a power supply.
Message posted on 10 Oct 2025 02:33 PM
@TimmyBGood wrote:
@gmhaggis wrote:I see that the Gigafast+ Hub has 4. Is there anyway to uppgrade to this hub, without having one of the Gigafast+ broadband packages ?
I am actually on CityFIbre infrastructure. It was CityFibre engineers that installed the fibre network cable into my flat and the ONT is clearly branded CityFibre.
Message posted on 10 Oct 2025 02:42 PM
@gmhaggis Few out there that require no power and drop the speed to fast Ethernet but it's all your choice!
