Discussion topic: Upgrade issue
Message posted on 09 Apr 2026 03:51 PM
Upgrade issue
I updraded my wifi a couple days ago and the internet has been super slow since i'm having more issues with a the better wifi
Message posted on 09 Apr 2026 04:40 PM
Re: Upgrade issue
Try running this line test to see if it finds any faults:
Message posted on 09 Apr 2026 04:41 PM
Re: Upgrade issue
i have already tried this
Message posted on 09 Apr 2026 05:34 PM
Re: Upgrade issue
And the result was....
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
