Discussion topic: Upgrade from old copper network
Message posted on 20 Jul 2026 04:54 PM
I need to upgrade from the old copper network but don’t have any mobile signal at home. Sky say they won’t upgrade me as I won’t be able to make emergency calls if the power goes down. This is the same situation I am in now so nothing would change. How can I persuade them to upgrade me?
Message posted on 20 Jul 2026 05:44 PM - last edited: 20 Jul 2026 05:49 PM
Re: Upgrade from old copper network
Perhaps a new mast was activated last week and has hugely improved the local coverage...
If you fall into any category which might be regarded as vulnerable, the ISP is obliged to provide an Uninterruptible Power Supply unit.
Message posted on 20 Jul 2026 06:09 PM
if you have power cut , then you need an alternative to contact emergency services for unfer 5.00 you can remain safe with nokia phone free 100 mb sim
Message posted on 20 Jul 2026 06:18 PM
Which relies on there being local cellular coverage...
Message posted on 21 Jul 2026 07:42 AM
That's the issue. We don't have mobile reception
Message posted on 21 Jul 2026 08:33 AM
@Haves+off+again when did yoy check with Sky about axswitch to full fibre? There have been recent changes for people in your situation somif it was afew months agon it msy have changed.
Message posted on 21 Jul 2026 09:22 AM
any isp provider will need to ensure , that one has a secondary means of calling out,
Message posted on 21 Jul 2026 10:36 AM - last edited: 21 Jul 2026 10:42 AM
True, but Ofcom doesn't define how this should be achieved. Bizarrely they also still think that one-hour run-time is adequate for a UPS...
Message posted on 21 Jul 2026 11:51 AM
Yesterday 😊
Message posted on 21 Jul 2026 11:57 AM
Yesterday 😊
@Haves+off+again assume that is answer to my post. In that case you are currently stuck. It maybe would checking the Openreach information on your line using this checker Openreach Checker
Use your full address and if you want help,in understanding the output then podt a screen shot of the full table and first three lines of the notes after removing the reference to your address.
