Discussion topic: Unsuccefu ll connection
This message was authored by: John1053
We have gone through the instructions and pressed  and hold wps button  unsuccessfull
Re: Unsuccefu ll connection
@John1053
Have you pressed the wps button on both devices, so hold the one on the hub for 5 seconds until the lights flash then go to do the same on the device you are trying to connect to your network.
Avatar for John1053
Level 0 icon
As I said we have an unsuccessful connection
