Discussion topic: Unreliable wi fi signal
This message was authored by: Robwhunderpants
Wi fi signal constantly dropping out, been going on for months, sky says there are no issues
Re: Unreliable wi fi signal
@Robwhunderpants Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
This message was authored by: Ariadnemaia
I feel your pain.
Same here. Upgraded to 105 fibre last week. Nothing but problems since with signal constantly dropping out. Had same issues with standard broadband. When the system is checked they say everything's fine but it isn't. Seriously annoying.
