Discussion topic: Unreliable connection
This message was authored by: Patrick95
There are still times when the WiFi signal drops out at the rear of the house. I have placed the extender half way between the hub and rear house location. Is it possible to get a second extender?
Re: Unreliable connection
@Patrick95
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
