Discussion topic: Unreliable and dropping connection
This message was authored by: Shyamal2
Message posted on 09 Oct 2026 05:50 AM
Before the external cable damage, all my devices worked perfectly. This was 2 weeks ago. Since the five-day outage and subsequent engineer reconfiguration, my Hive Hub, internet connection te devices and Sky Q (internet) have been unreliable. Your engineer warned there could be internal issues. I need the line stability, internal connections and router configuration investigated.
Find out more
Message posted on 09 Oct 2026 05:52 AM
Re: Unreliable and dropping connection
You are talking to other customers only on here and not Sky support so if you want this investigated you will need to contact Sky.
