27 Jun 2023 01:35 PM
I am unable to access a series of connected websites when I am at home going via my Sky router.
I used to be able to access them from everywhere. I can still access them on my devices from other routers and using my phone as a hotspot. Friends also loose access when they try via my router.
I have rebooted the router.
All was fine until about a month ago
27 Jun 2023 01:48 PM
Posted by a Superuser, not a Sky employee. Find out moreCan you let us know what the pages are & if you have Sky Shield enabled or not?
27 Jun 2023 02:08 PM
@jamesn123 www.bannerdown.co.uk I don't know if I have sky shield enabled but have not made any changes to that so unless it can be changed remotely by sky has been a constant
27 Jun 2023 02:11 PM
Posted by a Superuser, not a Sky employee. Find out moreYou can check if its enabled/disabled at this link
https://www.sky.com/myaccount/bb-and-talk/broadband-shield
27 Jun 2023 02:12 PM
@jamesn123 I have checked and sky shield is enabled but even adding the website to allowed websites doesn't fix my issue ....
27 Jun 2023 02:42 PM
Posted by a Superuser, not a Sky employee. Find out moreThe exception list doesn't always work properly. Can you try disabling it completely? Also if possible can you try switching your hub off for 20mins as this will fetch a new public IP for your connection, just on the off chance that the one you are using is blocked in some way.
It would also be useful to know what the error message you see in the browser is? E.g. Connection denied, DNS lookup failure etc.
27 Jun 2023 05:10 PM
@jamesn123 I have turned shield off. The message is 'refused to connect' when I tracert I get about 6 steps in before getting no response.
I'll turn the router off for longer....
27 Jun 2023 05:25 PM
Posted by a Superuser, not a Sky employee. Find out more@AliArn that link loads on my Sky system but I have Broadband Shield disabled.
27 Jun 2023 05:35 PM
Posted by a Superuser, not a Sky employee. Find out moreRefused to connect can mean its an IP block, I would try the router switch off for 20-30mins
27 Jun 2023 07:16 PM
I have had the router off for an hour.... still no access! I have turned off shield but the Sky person I spoke to says that might take 24 hours to really be turned off! So I shall try again tomorrow ...
Thanks for your help and ideas
