Discussion topic: Unable to connect to work VPN
This message was authored by: LorraineTH
I am unable to connect to my works VPN via Forticlient, this has been happening for a week now. my laptop connects to the internet ok but will not connect to the VPN.  I have been working at my mums and had no issues whatsoever.
Re: Unable to connect to work VPN
@LorraineTH
Do you have a white Max Hub?
Avatar for LorraineTH
Hi, yes it is a white Max Hub
@LorraineTH
In that case the issue may well be the Sky use of Map-T, and the resolution to move your connection to a 1:1 mapping.  I'll escalate your post as this has to be done individually.
Thank you, that will save me an 80 mile round trip into work every day
This message was authored by: Lisa-P1987
 Thanks for escalating this. We’ve sent LorraineTH  an invite to chat.
Lisa - Sky Tech Team Expert
Hi Lisa, thanks for contacting me regarding VPN connection issues.
I am able to connect to VPN at work and other premises but NOT from my own home.
Have even purchased and change supplied CAT5e cables to CAT8 trying to resolve this issue, is there anything that can be done?
@LorraineTH
You need to talk to Sky on the chat popup not on the forum thread
I am NOT a Sky Employee
I haven't received an invitation to chat,
This message was authored by: AB86
Any update from Sky? @LorraineTH I'm in the same position and don't seem to be getting anywhere
Hi, they sorted mine out but said it was a temporary fix and not to turn off my router, a proper fix was scheduled for sometime in September but I haven't heard anything since
