6
Discussion topic: Unable to change SSID and Password on Sky Broadband Router
This message was authored by PumpedBanjo This message was authored by: PumpedBanjo
Hi all,
I'm returning to Sky Broadband after being with BT for around 4 years.
I amended my SSID and password on the BT Home Hub and I want to do the same on my Sky Broadband router so that my Echo dot's, Sonos, Printer devices amongst others reconnect when my line switches over on Wednesday and I swap from the BT Hub for the Sky Hub.
I'm not super technical, but understand things to a certain degree and have accessed the router via ethernet into my macbook on address 192.198.0.1, however, when I attempt to change either the SSID, password or both at the same time, the webpage refreshes, advises it cannot connect, then if I'm lucky I get a 404 error.
Once I log back into the router, nothing has changed.
I've tried to hard reset the router, holding the reset pin down for 30 secs, then retrying, but to no avail.
Am I missing something glaringly obvious here? Unfortunately, I do not have a windows device to perform the change on, surely its not the Mac that is causing it?
Any help or assistance appreciated!
Thanks,
Danny
This message was authored by Chrisee This message was authored by: Chrisee Answer
Re: Unable to change SSID and Password on Sky Broadband Router
@PumpedBanjo there is a known issue with devices running ios and Safari with the Sky hub interface. Ideally use any other device otherwise Chrome seems less of a problem but need a few attempts.
@PumpedBanjo  Which browser are you using to try and make these changes with to the Sky router?
PumpedBanjo
Hi @Highlinder, I'm using Safari. Would you recommend a different browser? Cheers.
PumpedBanjo
Hi @Chrisee, Thank you. I'll try Chrome, if that doesn't, I'll try source a windows laptop. Thank you.
PumpedBanjo
Thanks @Chrisee - That's done the trick and I'm ready for my switchover tomorrow. Thanks again.
PumpedBanjo
Sorry, I wasn't specific enough for anyone reading this in the future - I used Chrome on my MacBook and this allowed me to perform the changes.
