Discussion topic: Ultrast Max Wifi Speed
Message posted on 11 Jan 2026 12:03 AM
Hi,
I have subscribed for Ultrafast Max 1GB home broadband.
Speed on ethernet is 900MB.
However, speed on wifi is between 350 to 550MB and I am only 10 CM away feom router.
So, wifi speed is a lot lesser from what I expected.
I've called customer support not helpful at all.
Router model is SR203, thought that I've received wrong router.
However, customer support says it is correct router.
Furthermore, it was awful customer support.
Don't we get 213 router in ireland?
Can someone advice what is the ideal wifi speed on ultrafast max?
Thanks in advance.
Message posted on 11 Jan 2026 12:44 AM
Re: Ultrast Max Wifi Speed
@Bogboss Think ROI is stuck on the SR203 as the default hub, and about 600Mb/s on a wireless wifi connection is really about as good as it get's!
