02 Jan 2023 05:52 PM
Hello, apologies if this is posted in the incorrect area.
I'm having Ultrafast+ and Sky Stream installed on the 11th. I'm aware they'll be running a new line for the internet, but as I'm a builder I'm wondering if there's anything I can do ahead of time to help them out RE: the install. Digging the garden to lay a pipe, pre-run a string to pull cables in the preferred spot etc, etc.
The more I can get done ahead of time for the engineer the better, basically.
Thanks.
02 Jan 2023 06:26 PM
Its an overhead feed with no anticipated issues therefore no preperation is required on your part apart from being there for the installation of the ont
02 Jan 2023 05:55 PM
Could you enter your full postal address below and post the table and the notes below after removing your address from the image
02 Jan 2023 06:21 PM
02 Jan 2023 06:29 PM
Cheers for the help.
