Discussion topic: Ultrafast 1
This message was authored by: sonytv55
Ultrafast 1
Ultra fast 1 router is connected into sky q box ok
I am getting tv notifications on tv screen stating WIFI lost. This is intermittent and disappears after a 1 min
I have reset the netwoek on the tv several times
Can I connect from the router direct to TV with ethernet cable
Regards
Re: Ultrafast 1
@sonytv55  You should be able to add an ethernet cab;e to the TV, but may need to go into your TV settings menu to reconfigure it to switch to ethernet.  Your TVs manual will guide you.
Avatar for sonytv55
Level 2 icon
Re: Ultrafast 1
Ok thanks for the reply
There are 2 yellow ports and a purple port which are vacant. Do you have any idea which one to use
Regards
Re: Ultrafast 1
@sonytv55
On a Sky Hub the yellow ports are ethernet RJ45 sockets.
The purple one will be for an incoming copper broadband connection on an RJ11 plug and not relevant in this context.
Avatar for sonytv55
Level 2 icon
Re: Ultrafast 1
Regards
