Discussion topic: Two amber lights
Message posted on 19 Sep 2025 12:52 AM
Two amber lights
My sky router has two Amber lights. Sky have confirmed there is no maintenance work in my area and everything from their end is fine. What is my next course of action as disconnection and connection not working
Message posted on 19 Sep 2025 04:50 AM
Re: Two amber lights
Sky won't have confirmed there is no maintenance taking place after the lines close. Openreach don't prewarn their ISPs of such work.
When there are issues between midnight and 7am it's usually going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If it's not use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
