Discussion topic: Internet not working
Message posted on 19 Sep 2025 12:28 AM
Hi
my internet is not working . In the service checker it is showing everything is goood but internet link is down in the modem the phone is not available to check on that port and verify it
Message posted on 19 Sep 2025 12:38 AM
Re: Internet not working
We are currently having the same problem, no internet.
Message posted on 19 Sep 2025 12:42 AM
Same here. East London / Essex area...
Message posted on 19 Sep 2025 01:28 AM
Wifi not working on tv
Message posted on 19 Sep 2025 01:40 AM
Internet is not working. East Londn area. There is no issues on the outage in our area.
Message posted on 19 Sep 2025 02:39 AM
Internet isn't working in east London / Essex area
Message posted on 19 Sep 2025 04:45 AM
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If it's not, use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
