Discussion topic: Tv restart
This message was authored by: Candicane
Message posted on 27 Jul 2025 07:21 AM
Tv restart
The tv won't restart after the electrician has turned off the mains for work to be carried out
Find out more
Message posted on 27 Jul 2025 07:30 AM
Re: Tv restart
@Candicane not sure shy you have pisted in the forum discussing Sky Broadband if your TV wont turn on. If tge problem is the TV connecting to the Sky hub then try rebooting the hub which may work. Otherwise if other devices are workimg normally sounds like an issue with your TV.
