Discussion topic: Tv keeps dropping connection
Message posted on 07 Oct 2025 08:53 PM
Our tv keeps dropping connection and freezing in the bedroom
Message posted on 08 Oct 2025 07:32 AM
Re: Tv keeps dropping connection
@Natasha124 To stream video you need a steady wifi connection to the hub. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
