Discussion topic: No wifi again
This message was authored by: AlanFogg
No wifi again
WiFi keeps going off so can't watch tv
Re: No wifi again
@AlanFogg
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
