Discussion topic: Trouble with WiFi to xbox
This message was authored by: Den21
Kids are reporting lagging to Xbox's
Re: Trouble with WiFi to xbox
@Den21 if using wifi to connect the Xbox this issue is most likekly poor wifi in thst room. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi. However there is another option which is to buy a powerline networking kit tgst ueses your home's mains wiring tingetvthe data to the xbox rather than wifi which works well in most homes.
