Discussion topic: Tramore Wifi down
Message posted on 12 Aug 2026 11:58 AM
Tramore Wifi down
LAN flashing and no internet connection
Message posted on 12 Aug 2026 12:07 PM
Re: Tramore Wifi down
In view of your forum username I presume Tramore is in Ireland?
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
