Discussion topic: Ticking noise from sky hub ?
This message was authored by Davidph This message was authored by: Davidph
Re: Ticking noise from sky hub ?
Of course I hit apply, and restarted the router too.
https://i.imgur.com/jYBYYCy.png
This message was authored by vegan74 This message was authored by: vegan74
I cannot save the Wanoe, it always goes back to DSL
Also cannot save the checkbox: Default DMZ Server - it always goes back to checked and 0.0.0.0
I do press Apply.
This message was authored by JoSand This message was authored by: JoSand
It's been a long time since the original post, but I'm so happy the suggested fix has stopped the ticking that I had to reply. Thanks so much!
This message was authored by JaneD56 This message was authored by: JaneD56
I have exactly the same issue???
I have no idea how to do any of this? Will sky send me a new router?
This message was authored by Zodd This message was authored by: Zodd
Request to speak to tech support who may walk you through the method described. Customer Support will send another router but it will be the same.
This message was authored by Jess46 This message was authored by: Jess46
Having the same issue!!
This message was authored by frankenstein2012 This message was authored by: frankenstein2012
Had the hub on my home office desk for nearly 2 years, ticking noise started yesterday driving me crazy.  The fix on this thread sorted the issue after applying and rebooting.
