Discussion topic: Thurles outage
Message posted on 03 Dec 2025 01:54 PM
Thurles outage
Message posted on 03 Dec 2025 01:57 PM
Re: Thurles outage
@Seanos1985
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 03 Dec 2025 01:59 PM
Re: Thurles outage
I now see you're in the ROI so some of the above links may not apply or work.
Message posted on 03 Dec 2025 02:33 PM
Re: Thurles outage
@Seanos1985 wrote:
Yet again down in my area , can I get an opt out of my contract it just isn't reliable
You would need to negotiate that with Sky, but note that if the issue is in the local Openreach infrastructure then most other ISPs would just inherit it.
