Discussion topic: Third party router bypassing sky hub
Message posted on 12 Jan 2024 08:32 PM
Hi,
I have a third party router and I want to connect it direct to Open reach box (bypassing my sky hub). Is it doable ?
Message posted on 12 Jan 2024 08:34 PM
Re: Third party router bypassing sky hub
@dejavu94 Take a look through this forum as there are many threads about this.
Message posted on 13 Jan 2024 09:36 PM
but there is so much experimental information it becomes difficult for a novice like me to navigate to the one that really works.
Message posted on 14 Jan 2024 08:21 AM
@dejavu94 short answer for the UK any third party router either needs support for DHCPv4 Option 61 which wotks on all lines and/or support for DHCPv6 PD which works on most but not all lines. Asus routers are popular and support both authentication methods.
Downsides loss of Sky support - you will have to reinstall Sky hub to get that - and loss of the voice line. Its impossible to make a recommendation without more detail like what you are trying to achieve thst the Sky hub cannot do and some idea of a bubget as routers run from £50 to £300 or more.
Message posted on 14 Jan 2024 08:55 AM
Thank you 🙂
Parental controls and the ability to block/ pause/ time limit a certain application on our children devices WITHOUT the need to pause whole device. That's the only reason we are moving to third party router as they come with more comprehensive parental controls.
Pausing/ unpausing whole device is not going to help as children have their school applications on the same device.
Wifi Max upgrade doesn't help. As per our survey Netgear, Tp Link and ASUS offer such functionality in their parental controls.
Message posted on 14 Jan 2024 09:33 AM
@dejavu94 good reason but did you know the new Sky Wifi Max bundle offers controls to pause/allow connection at a devive level?
When you have decided on the router podt with its model number and brand and someone should be able to help you get it connected. However none of the parental controls yet invented can be guaranteed to work !00% of the time against a determined kid.
Message posted on 14 Jan 2024 09:49 AM
Tried Wi-Fi max. Like the basic level it does allow pause unpause devices. Nowadays that is a very obsolete function. The moment one device is paused kids come up with papa I need to access school homework. Don't forget all schools now have home, schedule, class activities, meals, etc all applications on mobiles.
Sky broadband buddy used to pause for example TikTok or YouTube so child is able to access the remaining device. We were very happy with buddy back in 2018-2019. It's a shame it didn't continue.
Now Netgear and Tp link are offering the same function through paid subscription and software linked with their router.
Otherwise I like sky hub it meets our requirements.
I will return once my router gets delivered.
Message posted on 06 Feb 2024 12:05 AM
Hi,
I have decided. It is Netgear RAX E300. What settings do I need to configure please ?
Shaz
Message posted on 06 Feb 2024 07:19 AM
@dejavu94 I found this thread which discusses connecting the similar RAX200 there maybe other threads if you use the forum search above.
In essence set up the new router to use DHCP v4 Option61 with a string anything@skydsl|anything the
| is a pipe symbol whichh separates the username from the password. You can also add the DHCPv6 PD method as well but the former method works on every Sky line.
Message posted on 06 Feb 2024 07:54 AM
The former thread marked with the answered solution ?
Message posted on 07 Feb 2024 01:29 PM
I am totally lost not sure where to go in Netgear nighthawk interface. Attaching few snaps if it helps please
