This discussion topic has been answered Discussion topic: Third Party Router
Message posted on 12 Sep 2024 07:57 PM
Hi all
I am in Ireland and have been using sky FTTP for a few years now. I have always used my own Asus router using anything@skydsl for the option 61 setting. I have never had any issues with this but today it just stopped working. I rebooted the Asus and the ONT several times but it would come back for a couple of minutes then go again. I plugged in the sr203 and it works perfect. If I plug the Asus back in it goes again. I havent changed any settings so wonder if Sky has changed something??
Message posted on 14 Sep 2024 09:36 AM
Came home from work yesterday to find the broadband down. A reboot of the sky hub and it came back. Seems like there might be a problem with the line and not the Asus after all
Message posted on 13 Sep 2024 01:34 PM
Re: Third Party Router
What model is the Asus router?
Which Sky hub do you have that works?
Message posted on 13 Sep 2024 02:44 PM
Hi
I have an Asus RT-AX82u and a SR203 hub. I haven't changed anything on the Asus so either Sky changed something or the Asus got a firmware update over night that broke it
Message posted on 13 Sep 2024 02:50 PM
Could you post the wan settings screen and the lan->iptv vlan id vid screen
Message posted on 13 Sep 2024 02:52 PM
@cookiemonsteruk I'm in work but will post later!
Message posted on 13 Sep 2024 03:18 PM
Would also be useful if you could check to see if its done a firmware update. If theres no logs on it, you could check the asus website to see if there was any versions released recently.
Message posted on 20 Sep 2024 01:32 PM
@naalssh I have the exact same issue. Got home yesterday with the wifi down, rebooted the ONT and router numerous times, nothing working.
I'm using an Asus RT-AX88U with the option 61 setting.
If I put the original Sky Router back in place, it works.
