Discussion topic: Third Party Router Help
This message was authored by: Phil0705
Hello
My dad currently has Sky Full Fibre 500 (ONT on the wall, with a SR213A-02-UK-wht router).
I have an old Linksys WRT3200ACM flashed with OpenWRT that I want to use instead.
I have tried with the Client ID as the "[email protected]" in hex, or whatever it was, and I don't get an internet connection (but I do get a public IP).
I am seeing conflicting methods on the forums.
Can anyone advise if this router is suitable and what method I should be using?
This router is suitable for my personal Vodafone connection, using the same ONT.
Re: Third Party Router Help
@Phil0705 open wrt has the ability to support the necessary DHCPv4 Option61 with the string anything@skydsl|anything
Or the alternate DHCPv6 PD which soesnt require the string which works on the majority but not all Openreach fibre lines.
