29 Oct 2023 04:21 PM
The sky booster power light keeps flashing amber And I've tried ro reset and disconnected extra but nothing is working
30 Oct 2023 07:16 AM
Posted by a Superuser, not a Sky employee. Find out more@KayMarieCee flashing power light usually means the unit is resetting itself however if it doesnt sort itself call Sky as your booster could be dodgy. The y will replace the unit if they supplied it but be warned some units lack the Ethernet port if you use that.
